Need advice on northbridge cooler
30 Jun 2005
I've never had to change the cooler on one before but today the fan started making an horrendous buzzing noise. I'm looking to replace it with something passive. However I dont know for sure what is compatible with my motherboard. Does anyone know if the Zalman ZM-NB47J Northbridge Cooler (SY-007-ZA) works ok with this motherboard http://msicomputer.co.uk/Products.aspx?product_id=703542&cat_id=77 ?
Thanks in advance
Thanks, as I mentioned I've never fit one before, are they easy to fit? Will I have to remove the motherboard from the case or is it possible without taking everything out?
You will have to take the mobo out & just pinch the two plastic pins to get the old one off
The zalmans are good coolers btw ;)
Rob
Sometimes you can twist and pull them hard and they will pop out, but usually you'll need to take the mobo out as Rob says.
