Need advice on overclocking a 9700 pro
4 Feb 2003
telford, shropshire
hi,
got a 9700pro for a friend and looking at overclocking it, never had an ati card so not sure of the best way.
tried atitool on me works lappy and when i set it to find max memory it went from 180 to 390 :eek: so got a feeling i havent set something or doing something obviosuly wrong.
any ideas ?
thx
Yeah, I never use the "find max" feature in ATi tool as it always seems to go way too high. The best way is to just increase the clocks in ATi Tool (one at a time) 5-10MHz from the default and then test with 3DMark for stability. You may be lucky and have a good clocker, like my old 9600XT, or unlucky and get a bad one like my wife's X700Pro. Good luck!
