Dear members of Overclockers forum...
I was just wondering if you could help me in sorting a problem out that I'm having with a computer that I'm in the process of building. I am putting Windows XP on a RAID system and soon I shall be buying some of the latest hard drives for it from Overclockers. I am gonna get 4 Western Digital Hard Drives with 1 TB on each (the 64MB cache ones). I am going to build the 4 drives in RAID 10 or RAID 0+1 as they call it also.
There is no problem with me using my motherboard for RAID as I have a ASUS P5Q Deluxe board and it can take up to 6 RAID SATA ports in total. The problem is that once I have set the RAID up so that half my system will be striped and the other half (the other 2 TB's) will be mirrored, if I put Windows XP on this setup then what happens if I have a problem with XP once it's installed and I have to reinstall it again? I mean that if I have all my files on the RAID together then if I have to reinstall Windows XP again will it mean I will have to completely delete everything in order to get XP back on my machine again and get it running?
Normally I use McAfee Total Protection 2009 to protect my system so it's usually rare that I have a problem but sometimes I know how it is and you can get spyware or something that can damage the operating system leaving you with the only option to reinstall it completely.
What I do currently is to partition my 2 hard drives into different partitions (4 partitions but nothing like a RAID setup) and I find that putting my Windows XP installation on the first partition on the first drive means that I only have to format the first partition without losing the rest of the data stored on the other partitions.
How will this change over to a RAID 10 affect me compared to the old way I've got it set up? If I have to wipe everything on the RAID because of the fact XP has stopped working, do I have to lose everything on the RAID?
Thanks in advance for your reply/replies...
I hope I can gain more of an understanding of RAID before I eventually buy some hard drives that will probably cost me around £300 nearly in total...
