Need advice on upgrading my monitor
13 Jan 2012
United Kingdom
I currently have an old 22 inch monitor and looking for something 24 inch and sharper with a budget of £165 max. im planning on playing pc and ps3 on it.
ive been looking at these monitors
http://www.overclockers.co.uk/showproduct.php?prodid=MO-028-AS&groupid=17&catid=510&subcat=
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black [VE247H]
http://www.overclockers.co.uk/showproduct.php?prodid=MO-160-SA&groupid=17&catid=510&subcat=
Samsung S24A300BL 24" Widescreen LED Monitor - Glossy Black [LS24A300BL/EN]
http://www.overclockers.co.uk/showproduct.php?prodid=MO-044-BQ
BenQ EW2420 24" Widescreen LED Monitor - Black [9H.L1WLN.IBE]
or if their is better one out their for the same price, dont mind disconnecting and reconnecting cables for the ps3
The BenQ is the odd one out here, unlike the other two it has a VA-panel which does mean a better picture with much deeper blacks but for gaming it's not so great due to the color transitions being a tad slow which may result in ghosting.
If you're after a <£165 24" gaming monitor I recommend the IIyama Prolite E2473HDS it's been the advice for the best buy guides of two major Dutch IT sites (tweakers.net & hardware.info) for months now.
Hasn't been tested by the same site nor does anyone seem to have any test data on it, simply comparing the manufacturer numbers is useless as those don't tell you anything. So.. no idea :)
