Need advice on w\cooling kit
20 Mar 2004
Salisbury
Hi Guys
I'm looking to watercool my PC as I'm fed up with the noise from all the fans (not half as annoyed as my missus is though!). I'm running an Opty 146 which will be at 2.8Ghz and two X1900xt's. I had originally hoped to go with a reserator but don't think that will cope having read the comments on these forums. So I'm now looking at the Swiftech Apex Ultra. Will this be okay to use and would I be better off getting the alphacool NexXxos Ati coolers or just use the Swiftech GPU blocks with some ramsinks? Its all in a Lian-Li V1000+ case so I might have to use the radbox and mount the radiator on the back of the case. Any opinions?
Stick with the MCW60s which will do you very well. For a noob, the Swiftech APex Ultra is an exceptional introduction to water-cooling.
