Hi.
Want to spend some money at overclockers.co.uk, since they have great prices. Sorry for the long post, tried to put in as much detail so that you're as clued up as possible. My ancient CPU is an athlon XP2000+ and failed the Tomb Raider Underworld test on the 'can you run it?' site. My AGP 7600 GS only barely passed one notch over minimum. It's tomb raider underworld that motivated me to upgrade, and for future games as well as general pc stuff. My budget is ideally £300.
I want to try and keep my computer case (16.5" tall x 16" long x 8" wide) to save money which has an old ATX form factor asus board at the moment, and this new motherboard (see spec below) is about the same dimensions, fractionally smaller, as my current motherboard. If you think I can get away with keeping it?
Current asus A7V8X mobo ATX - 30.5cm X 24.5cm
New Gigabyte mobo ATX 30.5cm x 21cm
My case also has an 'EZ Cool' 550w PSU which is 3 and a half years old but seems to be fine, which I'd also like to keep to save money. I hope it will be powerful enough to run everything? EDIT: I've read EZ Cool is cheap crap, so maybe it's dangerous for my other components to keep it? I also read that a 600w EZ Cool is actually only 300w. Oh dear, more money to spend.
I've put together a selection of upgrade components which just goes a little over what I wanted to spend. And that's only if I can keep my current case and PSU. Can you tell me if these components will be good to go for the game, and for maybe one or two other higher specced games out there? What do you think?
£91.99 PROCESSOR
Intel Core 2 Duo E7500 LGA775 'Wolfdale' 2.93GHz (1066FSB)
http://www.overclockers.co.uk/showproduct.php?prodid=CP-272-
IN&groupid=701&catid=6&subcat=793
£56.99 MOTHERBOARD
Gigabyte GA-P43-ES3G Intel P43 (Socket 775) PCI-Express DDR2 Motherboard
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?__ProductID=2960
http://www.overclockers.co.uk/showproduct.php?prodid=MB-217-GI
*** just found out this motherboard doesn't support that processor, nor any of the other gigabyte ones, except for a couple which aren't PCI-E 2.0 and only support 8GB ram. Any other mobo you can recommend from overclockers?
£59.98 HARD DRIVE
Western Digital Caviar Green 1TB SATA-II 32MB Cache - OEM (WD10EADS)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-246-WD
OR £60.98
Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
http://www.overclockers.co.uk/showproduct.php?prodid=HD-211-__SE&groupid=701&catid=14&subcat=
*** Someone said to me that seagate are more reliable than WD, true or false?
£40 MEMORY
OCZ Gold Edition 4GB (2x2GB) DDR2 PC2-8500C5 Dual Channel (OCZ2G10664GK)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-149-OC
GRAPHICS CARD - don't know yet. Gainward GeForce 9800 GT Green Edition 512MB at
£70.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-109-GW
OR Sapphire ATI Radeon HD 4850 512MB GDDR3 at £79.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-179-
SP&groupid=701&catid=56&subcat=938
*** The 4850 is only £9 more but I've read it outperforms the 9800 GT by approx 30%, would that be about right?
I also don't know if one of these cards will fit inside my case better than the other. How much bigger are they than my 7600 GS?
Many thanks for any help.
Want to spend some money at overclockers.co.uk, since they have great prices. Sorry for the long post, tried to put in as much detail so that you're as clued up as possible. My ancient CPU is an athlon XP2000+ and failed the Tomb Raider Underworld test on the 'can you run it?' site. My AGP 7600 GS only barely passed one notch over minimum. It's tomb raider underworld that motivated me to upgrade, and for future games as well as general pc stuff. My budget is ideally £300. I want to try and keep my computer case (16.5" tall x 16" long x 8" wide) to save money which has an old ATX form factor asus board at the moment, and this new motherboard (see spec below) is about the same dimensions, fractionally smaller, as my current motherboard. If you think I can get away with keeping it?
£91.99 PROCESSOR
£56.99 MOTHERBOARD
£59.98 HARD DRIVE
OR £60.98
£40 MEMORY
£70.99
Just fine tuning now, basically, everything is ready to be bought. Wanted to ask you about the asus motherboard if I may. It's fine and all but I'm not sure (for future proofing in case I want to change to quad core) if it supports quad core or not. It says it supports AM3 multi-core processors, and CPU: Phenom II/Athlon II/Phenom/Athlon/Sempron. It doesn't say Phenom II x 3 or 4 though. For £2 more, there's the GA-MA770-UD3 which supports the processor I'm buying and quadcore. It's also ATX, not micro. Would you happen to know if I'm better off with one or the other? Even for just ease of fitting the ATX board perhaps? The only drawback for the GA-MA770-UD3 is a note that says " (Note 1) Due to Windows® XP 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB." Not sure how to interpret that, if it means more than 4GB won't get used, or it will but just falsely show less installed.
