Need advice/recommendations for a Router
26 Dec 2005
Liverpool
Hi guys,
I have zero knowledge about Routers. I am connected to Broadband via Tesco ISP at 2.2 Mbps via the Speedtouch modem. I am looking to connect my PS3 and Xbox 360 for online gaming etc.
I know I will need an ADSL router and I would like a router that is very easy to set-up and will allow to connect PS3, Xbox 360 and broadband.
Any advice or Router recommendations very welcome. I don't want to spend to much, say a budget of £60.
I am not sure if any other info is needed but very happy to provide if needs be.
Thanks.
Kudos - a post that a) says what type of router you're looking for and b) has a budget.
Netgear DG834G? If you don't want the wireless, you can always disable it.
