Hey guys my brother is building a rig specifically for bitcoin mining: a GPU intensive process.
He wants to build a system with 4x 6990s! (I know crazy)
Anyway I have a few questions:
Can you build a rig with 4 6990s? The most I've seen is 2
Will there be enough space on a motherboard to support 4 6990s?
Will the computer require a water cooling setup or will a sufficient amount of fans do?
Will a standard ATX case suffice? or will I have to purchase an E-ATX case
Will a 1200W power supply suffice?
The motherboard we are thinking of purchasing is a Asus Maximus V Extreme; it states that is support 4 way crossfire.
The case we're thinking of purchasing is a Fractal R4 or Fractal XL R2
The Power Supply we would purchase is a Corsair AX1200
