I got this Intel Core i9-11900K and im using a Noctua NH-U12 air cooler with 2 fans
Under idle i see it goes 40-43 C and i use turbo mode in bios where the cpu auto clocks to 5100 mhz
So the low temps are on idle 800-900 mhz .
Under stress test prime95 then i get 90-92 C
Under normal load it shows 50-55 due to some RGB lighting service from asus runs in the joblist and makes my cpu jump to 4800-5100 using turbo.
So i sort of want to downsize the temps by lowering the cpu volt if that is possible and will help ?
or should i just let it stay auto like this ? Im fine with the cpu going to idle like this. I just want to lower the temps with maybe 5 C
