[Need Advice]Upgrade For An Old Build
21 Oct 2017
Purchase Timeframe: Now
Budget:
Up to £2,000
Usage:
Gaming (GTA V, Vermintide II, Red Dead Redemption 2), Photoshop, Streaming?
Preferences:
I would like to upgrade current build for as little as possible. If a new PC would be a better way, then the budget may be around £3,500.
Current Hardware:
Case
: Corsair CC600TM; 265 mm; 592 mm; 507 mm; Black; 1x 200 mm; 200 mm (CC600TM)
Power Supply: Corsair TX850M Enthusiast Series TX 850W ATX/EPS Modular 80 PLUS Bronze PSU
Motherboard: Asus P8Z68-V PRO/GEN3 Motherboard (Socket 1155, ATX, DDR3, USB 3.0, HDMI, Bluetooth Module)
CPU: Intel Core i7 2700K @ 3.50GHz Sandy Bridge 32nm Technology
RAM: Corsair CMZ16GX3M4A1600C9 Vengeance 16GB (4x4GB) DDR3 1600 Mhz CL9 XMP Performance Desktop Memory Kit Black
Graphics Card: Asus GeForce Strix GTX 1060 (6GB) Graphics Card PCI Express 3.0 DisplayPort/HDMI/DVI-D
Internal Solid State Drive: OCZ AGT3-25SAT3-120G Agility 3 120GB SATA III 2.5 inch SSD and 7452GB Seagate ST8000AS0002-1NA17Z (SATA)
Wi-Fi Antenna: TP-LINK TL-WDN4800 N900 Dual Band Wireless PCI Express Adapter with Three Antennas
Cooling: Corsair CWCH80 Hydro Series H80 High Performance CPU Cooler
Operating System: Windows 10 Home 64-bit
Peripherals:
Not needed
Special Needs/Requirements (inc Wi-Fi):
Motherboard with Wi-Fi
I don't know anything about Vermintide II, but I think RDR2 and GTAV could be played with just a modest graphics card upgrade.
That said, 2K is enough to build a PC for 4K gaming, so you don't need to spend £3.5K regardless.
You don't state what resolution your current monitor is, but with such a budget and such an old system, you could be far better off building a new AM5 system.
Personally I see no point in the 9800X3D CPU's simply due to real world gains per pound until you get past the £700 GPU price bracket. Below is a rough idea of what you can put together for the sort of budget you mention. There are a lot of options, though with a 9070xt there really is no need to go past the 9700x, in reality most won't see much difference even with a 7600x. If the 9070xt is too much GPU, the 9060xt is a far cheaper option but still pretty good, and also doesnt need a huge PSU. Though with PSU pricing currently, 850w to 1000W is the sweet spot.
I play a lot of older games myself, and only recently upgraded from an old 4770K system, I came to the conclusion a 7600x would be a great starter CPU for my own AM5 system as it was available for £140 and recommended here on the forum, the 9600x is the newer CPU and not much more expensive.
GPU wise, I wa swanting the 9070xt or 5070ti, but to be honest with the majority of the games I spend time on, the 9060xt 16gb at £350 would probably be good enough for me, and with 24gb GPU's comming out in future, I am unsure of what current GPU's are worth it at current pricing.
if I was chasing more recent AAA titles at 4k 160hz, I would be wanting the 9700x or 9800X3D with a 5070ti/5080. But even a 7600x with a 9060xt 16gb would be a massive upgrade on any older system on the 115* socket.
My basket at OcUK:
Total: £1,445.88 (includes delivery: £0.00)​
My basket at OcUK:
Total: £1,843.84 (includes delivery: £0.00)​
My basket at OcUK:
Total: £1,090.84 (includes delivery: £0.00)​
£249 (incl. VAT)
£189 (incl. VAT)
£220 (incl. VAT)
£190 (incl. VAT)
£155 (incl. VAT)
£132 (incl. VAT)
£339 (incl. VAT)
£270 (incl. VAT)
£180 (incl. VAT)
£150 (incl. VAT)
£100 (incl. VAT)
£240 (incl. VAT)
£170 (incl. VAT)
£350 (incl. VAT)
£330 (incl. VAT)
