I'm in the middle of planning for a little project i have been thinking about for a while now, basicly it's a big picture frame fitted into a partition wall between my front room and my temp bedroom/workshop
the wall is plaster board with nothing in-between and will be using my current 20" Samsung and was going to use a beaten up old lappy to drive it (athlon xp / geforce mx2 ubuntu 9.10) but have now decided to also use it as an aquarium sim as well but i'm having a few problems finding a good one and the one's i have found don't have min specs
i do have a couple of other options, i also have my home server (running whs) and it's spec's are athlon 64 x2 3600+ 2gb ddr2 and 8600gts and a good old xbox360 hd-dvd drive with a salt-water aquarium hd-dvd but it's basicly just a vid of a fish tank and isn't really what i want so back to the screen saver option
so what i'm looking for is an awesome screensaver that will run on one of the options above and maybe other options i haven't thought of yet
if all go's well i will post a build log but not sure where's best to post it (if this is in the wrong forum could the mods please move it)
anyway should be doing this next week so will update when done
