The Antec 920 operates in push/pull as standard, so I'm not sure how that misunderstanding came about.
According to the in depth Vortez review it works best as an exhaust. When using it as an intake it drops the CPU temp by about 2C but raises the ambient temperature in the case too much. So the answer to that one is leave it as exhaust.
The general consensus for best airflow is lower front to upper rear and with just the Antec 920 and two front R4 fans that would work ok. Improving this particular setup gets confusing though because it doesn't conform to the usual air cooling convention because the 920 is connected directly to the outside, so doesn't exhaust hot air into the case. In The Big Air Cooling Investigation they come up with two interesting points, don't have an exhaust fan above the inlet to your CPU cooler fan and the single most effective fan in the whole case is the one you can fit in the side panel.
So going a bit off the usual beaten path, I would be very tempted to try this:
1) Antec 920 as exhaust
2) Have both vents in the top of the R4 open but just as vents, with no fans attached.
3) Fit the 140mm you were going to put in the top into the side panel instead.
4) Leave the two front fans sucking cool air into the case
