- 22 Jul 2012
- London
My 230mm version measures at 230mm outside edge to edge and about 203mm inside edge to edge.
You can stick the whole thing magnetically directly to the case or you can stick the magnetic adhesive bit to the case and use that to attach the filter if your case isn't made of metal
My sticky bit gets used as a convenient window frame when I don't have the filter on.
