- 8 Dec 2012
- UK
Hi all, I am in a situation where by I have large HGV trucks passing which cause vibrations in the floor.
I wish to reduce these vibrations on my computer case. They are not major but I do want to reduce them.
Does anyone have any ideas on any anti-vibration solutions?
Mine so far are as follows:
a) buy some extra firm foam material to put under the case to absorb the vibrations
b) buy some extra firm latex material to put under the case to absorb the vibrations
c) buy a rubber matt to put under the case to absorb the vibrations
d) Spring mounts - very expensive option!
Any advice is appreciated.
