Need an DSL router
Then just a big standard, whatever you can find the cheapest, Wireless N or G would be perfectly fine I'd imagine.
I use a couple of DG834GTs on my ADSL2+ for my network. One was free from Sky and the other I got off ebay for a few quid. The DG834GT is reportedly very good for ADSL2+ and can be flashed with custom firmware for SNR adjustments to get the best speed out of your line.
I did buy a cheap TP-Link TD-W8961ND but it never really connected quick enough for my liking and had some wireless issues. I'd avoid that model if I were you.
The Netgear DGN1000 seems to be a more modern, but ultimately poorer model than the DG834GT while the Netgear DGN2200 is considered an upgrade from it.
