Need an Excel Guru quick....
26 Mar 2007
Nottinghamshire
Right fellas I need help.
I have a massive file of data to process, there are around 79000 lines of data in this particular spreadsheet so a nice formula would help me here.
Basically a sample of the data is below and what I would like to do is where ever there is a 1 on the far right column, I need to insert automatically 2 rows directly below them. There are 6 columns in total.
H 42 13 03 A 1
H 42 14 01 A 0
H 42 14 01 B 0
H 42 14 01 C 0
H 42 14 02 A 0
H 42 14 02 B 0
H 42 14 02 C 0
H 42 14 03 A 1
H 42 15 01 A 0
H 42 15 01 B 0
H 42 15 01 C 0
H 42 15 02 A 0
H 42 15 02 B 0
H 42 15 02 C 0
H 42 15 03 A 1
Any formula to do this at all? MS help does'nt seem to return what I'm after so any help appreciated.
If you add a new macro into excel you can use the following code
I'm looking at your data and presuming that your 1's and 0's are in cell F
If I'm incorrect just change
Set myRng = Range("F1")
To
Set myRng = Range("A1")
Set myRng = Range("B1")
etc...
Code:
    Dim myRng As Range
    While myRng.Value <> ""
        If myRng.Value = "1" Then
            myRng.EntireRow.Insert
            myRng.Offset(-1, 0) = ""
            Set myRng= myRng.Offset(1)
        End If
    Wend
