Need an organisor. Help!
20 Nov 2004
Nock/Leicester
Hi all, i need a free organisor. My diary is no good anymore. Want something on the pc.
I have done a search and have seen people being recommended Rainlender and outlook. I have a m2000 pda so it would be nice if i had an organisor than i could sinc with it.
However i thought that outlook was just a simple email programme?
I want to be able to set reminders, make notes and keep appointments ect. can this all be done in outlook then?
Anyone use outlook and can tell me a bit about it and what exactly you use it for?
Also if i use outlook for organisor stuff, will i have to use it for email to or can i stick to using windows outlook?
Task in outlook is how I do it, you can drag and drop and e-amil and set-up all sorts of reminders!!
I use it for all my meetings and general reminders at work ;)
Can tell you days before about things or 10mins before and then recurring meetings etc etc!
There should be help guides at Microsoft I should imagine!
