Need answer/help fast!
22 Jan 2010
Brighton
New build i have just put togeather and is working great. But whenever for some unknown reason i try to install flash vs10 my pc restats, i have an SSD.
Everything else so far has been fine.
any one got any solutions?
problem solved, thanks for the input *cough*
No need for the sarcasm.. It was only 20 minutes before your first post. If no one knows the answer to your question or problem then you won't get a post.
Maybe you could post how you corrected the problem so we can help the next person that comes along with the same problem, which is far more productive and useful. :)
Quite so. Some problems can be very strange so answers are not always instantly available.
Yer sorry i was kinda busy finishing my new Build, if any one else has the same issue do not use IE8, seemed to be the problem. i chaned to mozilla and dl and installed and it was fine. sorry for the sarcasm :)
