I'm kinda new to this overclocking stuff. I've had a q6600 (B3) for a while now but I've been running it at stock for ages. I've finally got around to overclocking it and I've dived straight in at 9 x 333 for 3Ghz.
I'm running a q6600 (B3) on a Gigabyte P35C-DS3R. I'm also running 4GB (4 x 1GB) on DDR2 PC2-8500C5 1066MHz.
I'm just after a sanity check from you guys out there that know what you're doing to see if:
(a) is my overclock is ok? Do I need to change any of my settings?
(b) looking at my current temps, should I consider pushing my overclock higher? The temps at idle are: 40/42/35/31. The temps at load are: 61/61/59/59.
(c) are my memory settings ok? I think I'm underclocking my memory.
I've had to up the voltage a few times to get it to run Prime95 (Small FFT's) solidly. It completed a 22hr run last night/today without errors. Should I do anything else to test of stability? Large FFT's or Blend?
I'm currently running the CPU voltage @ 1.33125v in the BIOS. When I get into Windows, CPU-Z shows the CPU voltage @ 1.264/1.280v. So that's a vdrop of 0.06725/0.05125v - is that normal?
Also, under load the voltage drops to 1.232/1.248v - again is that vdroop normal?
Here's a screenie of my overclock settings/temps etc:
Here's 2 screenies of my BIOS settings:
Any help would be much appreciated! Thank you!
and takes up a lot of space. Have you tried with the noctua pushing air out the back? Or won't it fit that way?
, sell it on if you can and put the money towards a G0 or a Q9[3/4/5/]600
