Need your advice with new case fans.
I am still using the Thermaltake Armor case with the following cooling:
2 x 120mm front intake fans (icages which are empty),
1 x 90mm top centre exhaust fan (centre top),
1 x 120mm rear exhaust fan (above the I/O shield plate),
1 x 90mm rear exhaust fans (above the rear 120mm and behind the HDD cradle).
I would like to buy and change all these fans for something with better airflow but not to sure with what.
I am thinking for the top 92mm exhaust fan and the rear 120mm exhaust fan should be high airflow fans.
The Two 120mm front intake fans and the 92mm exhaust fan stuck in behind the HDD cradle (2 HDDs) they should be static pressure fans.
what do you think and any recommendations as to what to buy.
Thanks
worf105
Thanks
worf105
