Hi,
My main concern here is if these components would fit into this case, as I really like the look of it.
My other issue is knowing if they are all compatible, and weather I have missed anything out when it comes to building a PC Gaming setup,
I belive everything is there.
CASE:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-033-AE
- Expansion Slots: 7 Slots
- Dimensions: 460 x 200 x 540mm
- Motherboard Support: ATX / Micro ATX (Not sure about that?)
- Supports longer high-end VGA cards up to 280mm.
- Front Cooling: 1 x 120mm Fan
MONITOR:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-158-SA
GRAPHICS CARD:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-172-MS
PROCESSOR: i5
http://www.overclockers.co.uk/showproduct.php?prodid=CP-361-IN&tool=3
MOTHERBOARD:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-391-GI
POWER SUPPLY:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-053-CS&groupid=701&catid=123&subcat=1084
RAM:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-114-GL
OPTICAL DRIVE:
http://www.overclockers.co.uk/showproduct.php?prodid=CD-056-AS
HARD DRIVE:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-257-SE
I've been trying for months to get a good computer going, I would really like to get this over with a buy the parts already
Everything added up is around £800, and I really DON'T want to go over that unfortunately, thanks
CASE:
MONITOR:
GRAPHICS CARD:
PROCESSOR: i5
MOTHERBOARD:
POWER SUPPLY:
RAM:
OPTICAL DRIVE:
HARD DRIVE:
