ORI've completely NO SWEARING up a build for a mate, and hes bought the stuff and well.. yeah. I dunno how the NO SWEARING I've messed up so badly. I'll write down the spec and I really need you to check the compatablity of it, I think the motherboard is completely wrong, and if thats the only issue could you suggest another motherboard that would be compatable with the ram/gfx/processor? Would be great, thanks a load.
Intel Core™ 2 Duo E8500 3.16GHz, Socket LGA775, 6MB, 1333Mhz, BOXED w/fan
ABIT IB9, P965, Socket-775, GbLAN, ATX, 4xSATAII, DDR2, PCI-Ex16
OCZ Value 2GB Kit With 2x1GB PC5400 DDR2 667MHz, CL5-5-5-15(two sticks)
OR
Corsair Value S. PC5300 DDR2 2048MB, 256Meg x 64, CL5, 667MHz, 240-pin
(only one stick)
MSI GeForce GTX 280 1GB Super OC GDDR3, PCI-Express 2.0, 2xDVI/HDCP, 512bit
Samsung SpinPoint S166 160GB SATA2 8MB 7200RPM
Pioneer DVD±RW burner, DVR-215, 20x, SATA, Black
Corsair Powersupply 620W Black, ATX/EPS, 120mm Fan, 8xSATA, SLI, WxHxL 150x86x150
Sigh, be nice. I've NO SWEARING up
OR
(only one stick)
