Need case fan recommendations...
28 Aug 2006
I'm looking for the best, slim, silent/quiet 140mm case PWM fans.
They're going to be top mounted as an exhaust. The maximum depth space allowed for fan fitting is 23mm at most.
Any help will be welcome :)
What jaffveyda said.
Also, if there is on 23mm for fan, where is the air supposed to flow? We need about 50mm space between fan intake / exhaust for the air to flow to / away from fan. ;)
Raijintek is another slim 140mm
https://www.overclockers.co.uk/raijintek-aelous-alpha-140mm-red-white-fg-000-rt.html
Though it's not exactly standard 140mm "square" fan with frame bigger in one direction.
But really weird that only 23mm fan would fit if there's actually position for fan.
25mm is standard thickness, and any thinner fans are exceptions and lot thinner losing lots of air pushing power per rpm to that.
