Need cpu cooler & 2 fans
24 Apr 2009
Have a Gigabyte Poseidon case, so the cooler must be able to fit in it. Want something that will cool well and overclock my e6750 to 3ghz at least, its LGA775 Socket.. Also need two 120mm fans, not fussed on looks.
thanks
hmm is this case a fairly big one? the only thing I can think off is the True black but I think you need to buy the fans
right attach the 1900RPM fan to the front of the case to get positive pressure in you case then attach one 1200RPM fan to the heat sink and the other to the rear of your case:D
edit: didnt read the quiet swap the fans for 3 of these
http://www.overclockers.co.uk/showproduct.php?prodid=FG-004-NC&groupid=701&catid=57&subcat=4
