Need desktop Build
20 Apr 2012
Hi Guys,
Due to my laptop deciding to die on me i am in need of a desktop build ASAP.
My budget is about £350 can go slightly over if need. The price is only for the parts for the computer no keyboard or monitor etc.
I will be playing games like league of legends etc and using for general use
Cheers
Will you need Windows? If yes, did the laptop already have Windows 7/8? Could you extract the hard drive and try and access the data on a mate's computer - then use one of these programs to find the product key for your copy of Windows? http://www.techsupportalert.com/con...-product-key-all-current-versions-windows.htm
That would mean £80 can go towards hardware instead.
I have copy for windows 7 ill be able to access the data and that on it.
The budget is just for parts for the computer
Regards
Danny
