ok, i just order the follwing from here on friday, and was assured its all compaible (have removed software/peripherals from the list), so im ticking that off the list that could be wrong;
OcUK Value Hanns-G HW191D 19" Widescreen LCD Monitor - Silver (MO-017-OK)
Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN)
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
Connect3D ATI Radeon X1900 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-CO)
Seagate Barracuda 7200.10 200GB ST3200820AS SATA-II 8MB Cache - OEM (HD-085-SE)
NEC AD5170 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-041-NE)
ok, so, i've built a PC once before, but it was based on one of those bare-bones systems, where mobo and stuff is included. It also had a bloody good set of instructions >_>
this time having a mix of everything seems to half left me in the **** so to speak >_>
i've put it all together (as i best i can :S have had many (un)educated guesses), and now problems are
a) on the monitor i get 'no signal' message
im assuming its due to everything not being plugged together properly, but also related: the monitor to PC cord is male @ both ends, the monitor socket is female, but theres no compatible socket on the PC. There is, on the graphics card (is it dvdi?) slots (2), and with the card came two adapters to slot into dvdi sockets (though it seems one is busted, and wont fit - can i pick these up seperately?)
b) the CD drive has no power
c) the inbuilt fan, and processor fan do not turn on (though the one on the graphics card does)
d) theres unused wires everywhere
heres some pics:
http://i13.tinypic.com/330vl7m.jpg
http://i14.tinypic.com/42uo50k.jpg
http://i13.tinypic.com/2ugmakm.jpg
http://i13.tinypic.com/2eupsuh.jpg
http://i13.tinypic.com/2ypgadz.jpg
http://i14.tinypic.com/2r6h4qa.jpg
http://i13.tinypic.com/2ihmqnk.jpg
http://i14.tinypic.com/2wn1hdk.jpg
http://i13.tinypic.com/43ff5uq.jpg
would really appreciate help with this guys, even any handy web-site links would be muc appreciated - im pretty screwed otherwise :S
heres some pics:
