Mine was 2.88Ghz on stock (70C Orthos load), and 3Ghz with the Tuniq (50s Orthos load). I'm told I'm limited as it is an L2 revision and not M0. If the latter, people are getting 3.2-3.4 on quality coolers.
my L2 revision e2160 will clock upto 3.2, however my cheapo £7 a gig ram wont allow it, and my bro wont let me keep his crucial ram... so now im limited to 3ghz topping the ram out at 333mhz (667)
I only use a 16 quid thermalright HSF from ocuk, and at 3.2 was hitting 68, @ 3ghz it sits nicley at high 50's in stress test.
Hi there!
make sure it's a M0 revision and not L2!
Regards
