I am trying to repair a PCB control unit. This is the old relay
https://www.digchip.com/datasheets/parts/datasheet/1750/G5S-1-CB-DC24.php
It is an Omron G5S-1-E-CB 24vdc from a home appliance, single pole, class B insulation, 24VDC, plastic enclosure and coil voltage 5.
This is a chart of the current Omron relay range - I need help to select the correct one from the list within the first box:
https://omronfs.omron.com/en_US/ecb/products/pdf/en-g5q.pdf
Can anyone help?
BW pod
Can anyone help?
BW pod
- keep the fire extinguisher to hand!
