Need for speed 2015 freezing glitch
10 Apr 2014
Hampshire
just bought the game on pc to use my steering wheel(G25) and the game is awesome with it, much better than using a controller.
my only problem with the game is that it keeps freezing for a few seconds then it unfreezes. its making gameplay a little annoying as it happens very often.
has anyone with the game on pc had the same issue and maybe know how to fix it? thanks in advance(Y)
btw tried a couple of searches on google but didn't find a "fix"...
Right click on the game exe > untick Scaling on high DPI > tick Run program as an administrator.
Works for some, not all though.
I tried doing the thing that you suggested, and it didn't work. then after a little more time playing I turned it off and checked its properties.
the part about the dpi settings and scaling said "disable" , which was already unchecked. I checked it then tried the game again and that didn't work either.
got any more ideas?
Have you tried locking the framerate in the options ? Slap it in 1080res and lock to 30/60fps and test them both see if it stops the freezing/lag.
I'd just go the basics of setting it all to low and work upwards, hope you can sort it out!
