Need for speed most wanted & bounty
8 Oct 2005
Midlands, UK
Ok, i aiming to race the =9 person on the blacklist, have anough race wins and milestone events but lack over 100,000 in bounty to proceed :(
Has anyone got some good tips or similar to allow me to collect more bounty as some of the police chases are getting kinda annoying now. I heard a "bus glitch" will allow me to build up bounty faster and waS mentioned on some site a while back but can't recall it???
Please help......
Bus glitch...
Whilst in a pursuit, locate the bus station - big glass building you can smash through, fairly central on the world map, go inside and there are two ramps. Go up the right hand side one, and all the way outside on the walkway (its actually a roof for the shelter underneath)
You can just sit there and your bounty will increase. Their is a small chance the cops will follow you up the ramp, but it happens rarely.
When you want to end the pursuit reverse back inside the station, and just sit on the ledge in between the two ramps. Eventually you should evade the cops.
Alternatively, 100,000 bounty isnt that hard to get. All I do is keep on the big wide highways, keep up my top speed and just ram into cops and roadblocks.
I'm currently #3 on the blacklist, and am having a problem getting 200,000 cost to state. Should crack it eventually though.
hum thx, going to try that now. For this glitch does it matter what blacklist member im tryinbg to defeat?
Nope, works all the time.
Your best off going into the station with at least 3x heat though, otherwise there wont be enough cops to make it worthwhile.
Please help......
Just wait till you're on the last one like I am, wooooooo the bounty on there is massive! :eek:
Yeah lol, i built enough bounty while on no.3 in 1 go that i had double for no.1 it took like 1hr 30 mins to do the chase though on 5x heat...
When you unlock the area i the bottom left of the map, just start a pursuit there (using the blacklist menu - its the middle option at the very bottom). Stay on that highway for a very easy pursuit.
Computer cars also cant deal with the large spiral on this road without slowing down a lot. Take it at 200ish and you will loose all the police. Take the off ramp and pull in to the indoor area at the otherside of the car park (think its the car park of the stadium). There is a hiding area just around the corner in there.
I have got several 800k+ bounty pursuits easily through this method and there is no need for pursuit breakers :D
Nismo said:
Bus glitch...
I must be doing something wrong here :(
The police keep coming up after me, 2 cars at the same time just :( I can see the bounty increasing but a cop comes up the ramp and onto the bus to me:(
What am i doing wrong??
Onto the bus?
Dont sit on the row of buses, use the right hand side ramp and go along the thin roof which runs parallel to the buses.
Sit right at the end and you will find that the police get behind you very rarely though it does happen!
Nismo said:
Onto the bus?
stay on the right side of the right overhang, on the left side of the right overhang the level 5 cops sometimes get up there. to evade wait for the copters to go and reverse in and park right up against the glass rail (unbreakable).
Yes getting bounty is very annoying, think I'm trying to race #2 or maybe #1 but I just can't be bother getting the bounty.
Another tip for you which I tend to do a lot is race around the main highway for a while untill you have enough bounty then just dive into the golf course when you want to loose them, seems to work quite well I find :)
Yer i tried this, using the highways but its soo hard to loose em when you get heat level 5. I've got the gallado tripped to the max in everything and they still always keep up with me even though im travlling at 190 mph :(
I will complete this game, i will! ;)
Finished this the other day, have to say (without giving anything away) the 'race' after you beat Razor is pretty cool ;)
