14 Apr 2008 at 16:45 #1 sanofi sanofi Associate Joined 9 Jul 2006 Posts 1,848 Location Vienna Nothing heavy, just working on and internet browsing. I have mobo, cpu, ram, hdd and case already, just need these last two components. Under £100 pref but as low as possible. Thanks.
14 Apr 2008 at 16:58 #2 Blackhawk47 Blackhawk47 Soldato Joined 17 Sep 2007 Posts 11,117 Location West Yorkshire / Market Bosworth This should be more than fine for a home use pc. graphics card: http://www.overclockers.co.uk/showproduct.php?prodid=GX-151-AS&groupid=701&catid=56&subcat=708 PSU: http://www.overclockers.co.uk/showproduct.php?prodid=CA-016-OK&groupid=701&catid=123&subcat=1105
14 Apr 2008 at 17:06 #3 semi-pro waster semi-pro waster Man of Honour Joined 27 Sep 2004 Posts 25,821 Location Glasgow What Blackhawk47 has suggested looks fine but just to check, does the motherboard support PCI-E? If not you'll need a different graphics card.
14 Apr 2008 at 20:48 #4 sanofi sanofi Associate OP Joined 9 Jul 2006 Posts 1,848 Location Vienna semi-pro waster said: What Blackhawk47 has suggested looks fine but just to check, does the motherboard support PCI-E? If not you'll need a different graphics card. Click to expand... Sorry forgot to add, yes the mobo has PCI-E.
