- 3 May 2013
- Ireland
Hey.
So I'm doing my first build atm, it'll mainly be a HTPC. I have all/most of the components already, here's what I've got so far -
MOBO - Asus Z77 Sabertooth Intel Z77 (Socket 1155) DDR3 Motherboard
CPU - Intel Core i3-3225 3.30GHz (Ivybridge) Socket LGA1155 Processor (55W)
CPU Cooler -BeQuiet Dark Rock Pro 2 CPU Cooler
RAM - Corsair Vengeance 8GB (2x4GB) 1600MHz (CMZ8GX3M2A1600C9)
HDD - 2 x Western Digital Caviar Green 2TB SATA 6Gb/s 64MB Cache
SSD - Samsung 128GB SSD 840 PRO SATA 6Gb/s
PSU - Cooler Master Silent Pro Modular 2 720w '80 Plus Bronze' Modular Power Supply
Case - Sharkoon Tauron ATX Midi Tower - red
I will definitely be upgrading the CPU to an i5 or i7 at some stage, but I just wanted to get the thing up and running asap and price was a factor for the most part, but I did not scrimp on other not so easily upgradable components.
As you may have guessed I have been aiming to build a fairly quiet HTPC. However, I would like to be able to do some gaming on it as well, which brings me to my question -
What graphics card :
(a) is suitable/compatible with my current CPU + MOBO + PSU?
(b) could be used to achieve the best possible graphics on this machine assuming I upgrade to a better CPU?
(c) same as question (b) but if I upgrade the PSU as well?
I would like to be able to keep the noise level at a minimum but it's not really necessary with the graphics card as I will be wearing a headset when it is most likely to erupt with noise!
Would appreciate any advice, cheers lads.
*Note* I will be outputting to a HDTV.
