need hel with pc
18 Feb 2009
Hi all i need your help.Ive just put a 2nd hand hard drive i my old pc as it failed and i lost everything.
Im trying to put win7 on it.
It starts to post then comes up with this
CDBOOT cannot boot from cd Code 5
NTLDR is missing
Press ctrl -alt delete to restart.
Could it be a bad disc that win 7 is on.
Any ideas
The cpu is an athlon 64 3000+ 1 gig of ram and 256 mb gfx card
Any ideas or help will be apreciated.
Thanks
Kieves
Ive checked in the bios
In the standard CMOS settings i have this
Primary IDE master WDC wd400eb-11f (thats the HDD)
Primary IDE slave Not installed
Secondary IDE Master dvd RW
Secondary IDE slave dvd-rom
Then in the advance BIOS settings and boot sequence i have
1st DVD rom
2nd DVD rw
3rd wdc wd 400eb-11cpf0
Could it be the install disc?
