- 7 Sep 2007
I currently have the ABIT IP35 PRO and overclocks nicely however I did not realise it was a crossfire board and not an SLI board. And was looking into water cooling but dont have a lot of space etc.....
So my questions I need answering are as follows:-
1. What other motherboard that has the option for SLI would anyone recommend that would also have the same over clocking potential as the IP35 PRO ???
2. I currently have the Gigabyte Auroa case and currently with the IP35 and my 8800 Ultra and PCI Soundcard etc.. there is not any room for the pump etc for any water cooling and certainly any 2nd Ultra Card. Can anyone suggest me a case that has plenty of space to allow me to have 2 x 8800 ultra cards along with being able to use the available PCI slots (motherboard suggested in question 1 above)This case must be good for ventilation and cooling etc and space.
3. Also before I install Water Cooling what is the best air solution available, I currently use a Zallaman 9500 on my quad 6600 GO chip
4. I have also currently got a Tagan 750W Modualr PSU which has 2 dedicated PCI cables is it a case of buying a further 2 modular cables to plug into the psu to power a second card ?
5. Currently have 4gb (4x1gb) Ballistix 800mhz memory would i need to go for the next one up 1066mhz to remove any bottle neck when raising the FSB for overclocking ?
I thankyou in advance for any help you can give me as at the moment I am stuck for both space and the option of sli so have a few pc builds coming up so will take the opportunity in using my bits for these pc's and using the money to purchase the bits (suggested above) to give me a case with more space to accomodate a sli motherboard that has the same overclocking potential
as my current IP35 Pro and is easy to fit a water cooling system along with using 2 full size 8800 ultra cards and being able to use 2-3 PCI slots on the board.
So Please Help.. Many thanks again. Also any links or pics for the cases and board etc would also help
