Ok, sorry for the long message, but im having 2 problems currently..
Problem 1:
I recently got this bundle from OC, (Abit IP35 Pro XE Motherboard / Intel Q6600 Quad Core @ 3.20Ghz / 2GB (2x1GB) OCZ PC-8500 RAM / Freezer 7 Pro CPU Cooler) and am having some problems/ queries with it
Everything is sort of ok, I had some problems to start with, with fixing the freezer 7 cooler to the MB, as the plastic pins bent back, so I couldnt fix it, and in the end had to use the stock intel heatsink
Am currently running at stock speed (2.4ghz) but am having a few issues with temperature readings etc
I dont bother going by the bios readings as ive read with this MB that they arent correct, in windows though I am getting an idle temp using real temp of around 39-40 on each core, but if i run prime 95, and do some stress testing the temps shoot up rapidly to over 90, upto 100 almost
Surely this cant be right? ive been leaving the side of the case off as well, and even felt the heatsink and it doesnt feel hot, im sure its mounted properly as well.
Anyone know why?
Problem 2
Before I started to try and install my OS, I thought id have a go at trying the OC and getting my cpu to run at the guaranteed speed of 3.3gz stated on the instructions
Ive followed every page step by step, but no matter what, it doesnt seem to want to work
All im getting after saving the settings, is the system turns itself off, and then around 5 seconds later starts up again, but I dont get a beep or anything, and no boot menu/bios setup etc, I have to unplug the power for around 10 mins and then when I turn on the system again, it then boots up, but back to the settings I had before changing everything in bios
Im sure my PSU is powerfull enough, as its a 550W so it cant be that
All I have installed in the pci slots are my 2 nvidia 8600gts cards
Can anyone help?
Been scratching my head at everything for over 2 days now and am stuck!
Cheers
Problem 1:
Anyone know why?
Problem 2
Can anyone help?
Cheers
