Need help/advice on cpu bundle + case
13 Dec 2008
Hi all
Could do with some help or advice please if possible!
Ive had my current system for so long now and think its time to finally upgrade to a more powerful upto date 1 etc
I have been looking at this bundle in particular:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-063-OE
Question I have is, there are 2 options for motherboards, which of the 2 (ASUS/GIGABYTE) is the better? Ive looked at both and the GIGABYTE is £33 more expensive, why is this?
I also need to find a good case for this bundle, as the current 1 I have atm is so small I wouldnt even attempt to fit this inside it! So if possible I need a fairly cheap good quality 1 if someone can reccomend 1?
I do have a good PSU btw (750W) so that shouldnt be a problem hopefully
Thanks for your help!
Forgot to mention I have about 4 hard drives installed ATM and am planning to get a 5th in the near future so need a case that has plenty of room!
Anyone have any info at all please? WNt to they and get 1 of these in the next month or so
I'm also wondering how much my old setup would sell for as well, trouble is my mb isn't made anymore (abit) with my q660 as well + case...
