comp builder said:i bought this same processor yesterday and only just started the comp up and im about to overclock it now.
This is where i find it but i have a ASUS borad so this is prob no help at all but anyway.... i got to the 'advanced' tab then jumper free config, and the one below it and then finally into memory
do you know how to overclock? if you don't then i suggest you learn before you go messing mate![]()
. I try to update but nothing happens. my mate says that flashing the bios is the only way but a number of google searches have failed to give me an answer, also I don't have a floppy drive so if I do have to do this it has to be from cd.
