Hi all, this seemed like the most appropriate sub forum for this, so here goes.
I've tried making many 'bootdisks' using USB flashdrives, but I always get the problem when booting from it 'NTLDR is missing'. Everytime.
I've tried using various versions of DOS on the flash drive, i've used the files from guides on how to make boot drives, just about everything and they all end up with 'NTLDR is missing'
Is there any way around this? the reason I want to boot from DOS is so I can change my GPU's BIOS as I can't do so by any other means.
I'm using Windows 7, afaik that shouldn't prevent me from booting DOS using a properly made DOS boot disk?
Any help woul be grand, thanks!
.Is there any way around this? the reason I want to boot from DOS is so I can change my GPU's BIOS as I can't do so by any other means.
