Need Help Bought a XFX HD5830
I'd ring overclockers, give them your budget, tell them what you want the computer to be used for and I'm sure thy can point you inthe right direction for a base unit :)
Its an E521 perhaps not as old as i thought it was, just seems like ive had it longer.
Anyway, i got myself sorted- thanks for all the posts + help
was expecting to be flamed for being a nub and buying a card i couldnt run :p
What did you do ?
