Need help building/buying gaming PC
22 Oct 2019
Hello everyone
I’m looking to get a new gaming PC, I have a budget of £2k (including screen) and want it pre-built by OCUK.
I need some advice on how the pre-building service works - I know there will be a charge for using it, but can I choose whichever components I want and send them a list or does it have to be from a predetermined list? Will they install CPU fans and change case fans etc?
Also, I’m looking for advice on which components are best for my price range, its been a good few years since I last got my PC so I’m a bit outdated :)
In the past I have had AMD graphics cards/CPUs and I have been underwhelmed by the performance. I was looking to go Intel/NVIDIA this time, but I have read about Zen2 Ryzen processors being better for gaming money-wise if not overall.
Also would like to have RBG components and a case to show it off :D
Any help would be greatly appreciated, thanks!
In terms of the building, you can either just use the OCUK website and pick a pre-built PC, and most have some choices with the components via a pre-set list, otherwise you can list your component choices in the Customer Service sub forum, located at the top of the main forum page and ask them how much to build and deliver to you (plus I believe you get their excellent warranty as well, double check that).
As for parts to consider, ask in the 'New to PC Gaming & Upgrade Advice' forum, lots of knowledgeable users in there :)
Thanks for the reply I posted in both forums, I wasn’t to sure about making my own components list and having them build it so thanks for clearing that up for me
