Need help building pc
Permabanned
4 Nov 2008
Earth :-)
hi people what else do i need to buy to make this pc complete...like which cooling kit air type do i need to put on the cpu(heatsink etc) and what thermal paste...its my first build so i would like some help please
thanks
Corsair 4GB DDR3 Dominator 1800C8DF Twin3X (2x2GB) (TW3X4G1800C8DF) £294.99
(£346.61) £589.98
(£693.22)
Gainward GeForce GTX 280 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail £284.99
(£334.86) £284.99
(£334.86)
EVGA Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard £259.99
(£305.49) £259.99
(£305.49)
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - Retail £234.99
(£276.11) £234.99
(£276.11)
Corsair HX 1000W ATX2.2 Modular SLI Compliant PSU (CMPSU-1000HXUK) £159.99
(£187.99) £159.99
(£187.99)
Antec 1200 Twelve Hundred Ultimate Gaming Case - Black (No PSU) £115.99
(£136.29) £115.99
(£136.29)
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) £66.99
(£78.71) £66.99
(£78.71)
Samsung SH-S223F/BEBE 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
Personally, i'd change the ram to one of the triple channel kits. As they run within intel spec (1.65volts max, although i know there is divided opinion about whether running higher voltages actually causes damage)
I think you may be paying over the odds for the EVGA Motherboard unless it has something extra over the other manufacturers im missing?
What will the pc be being used for? (As i see you haven't specced additional HDD's or sound card)
Why 4 rather than 6gig at least?
Only slightly better performance increase with tri channel but meh, if your spending that much on 4 why not slip in 2 more?
+1
re
can u advise me on which triple channel kit to get?i want the fastest available can u point me in the right direction please?Also i went for the evga board as i heard its the best for overclocking and the best for tri SLI.....
i am using the pc for games only
Well again, personally, i go with OCZ or Corsair for my ram, so i'd say any of those kits.
Fair enough with the motherboard, will you actually be overclocking it? For what its worth; tri-sli doesn't scale well at all, each to their own though ;)
