Need help buying a new cpu .
I agreed that the fx9590 is a waste of time, I agree with you get a cheaper 83** or 8320e
I accept and welcome your apology on the boards capability, some peeps won't man up when they are wrong, you have which is great.
Peace
I think we need the 3 strikes rule in here as well as the gpu section. Too many threads are ruined by children argueing.
Op, please don't buy the overpriced 9590. Get a 8320/8320E and clock it.
Aye, I may well have been wrong on that.../snip
I think we are all on the same page here no need to carry that vibe on and agree with this advice the 8320E is the best option. I wont be bearing any kind of grudge David, and mirror what davedree said above.
Agree. Why the same faces jib in to a thread to constantly either defame Andy or promote intel can only be seen as a witch hunt or to stir trouble. Can be equally as bad as the GPU forum and especially off putting to most users!
AMD can be slightly cheaper but that may be reflected in performance in quite a few games as well. The fx8320E is the best value of the range and will normally clock pretty well, IMO its the only option going AMD, the higher priced ones are just "better binned" but that does not always mean better clocker. Nothing wrong with the sabertooth, it will hold the cpu just fine and will probably be able to clock to
9590 speeds pretty easy.
Good luck
