Hi all.
I want to treat myself to some filters that I hope will alllow me to experiment more with my photography.
I want a 10 stop ND to do the 'misty water' effect and a soft graduated neutral density filter for sunrises etc.
I have read an article about the pros and cons of circular vs square and I think I would rather go for square as I really like to shoot sunrises and apparently it's easier when using square to align to the horizon.
the 2 lenses I use most are both Ø72mm. I have a 12mm focal length Samyang too but I cannot find the diameter marking for it - let's forget it for now.
I don't want to spend a fortune but Im good with each filter costing say £40-70. (is this realistic?)
here's my dilemma:- there are so many different manufacturers and A LOT of information about adapter rings and it's just information overload, I can't deal with it.
Can someone just recommend me a system to go with - I need the 'holder' as well as the filters.
thank you so much!
thank you so much!
