Need help buying Mesh networking system.
30 Aug 2003
I am in the market for a mesh system with a budget of £200 I have read varying reviews about different systems but I am at a loss as to which to buy.
problem is I will read one review and they say what I am looking at is awesome then another review says its pretty rubbish.
So I am looking to you guys that have real world experiences to help guide me.
For info I am on Virgin M500 but wifi around the house unless in same room is pitiful.
Thank you.
im no expert, but we have a vodafone router and that was poor round the house. Recently bought a netgear orbi pro with satellite, using the vodafone thing just as a modem now and the orbi is the router. The orbi can ping the wifi connection across to the satellite elsewhere in the house with ease, we have perfect wifi everywhere now. Think it was about £300 but there were cheaper ones too from memory.
Unless you have 2ft thick stone walls, double course brickwork on every single wall, foil lined plasterboard/foil lined underfloor insulation on laminate or the kind of home that has a wing for the servants, getting decent WiFi is usually reasonably simple. Run a cable from the router to a central location on the top floor and drop it through the ceiling, connect a PoE injector at a convenient point (unless you have a suitable PoE switch) and mount an AP on the ceiling connected to your cable. You will now usually have decent WiFi on the top floor and the floor immediately below it, I even have decent coverage on the ground floor, though 5Ghz speeds aren’t so great.
If you prefer not to have an AP mounted where it can be seen, they survive quite well in roof spaces which can make installs quick/easy. Larger homes or homes with extensions may need additional AP’s, for example my parents bungalow has a 2ft stone wall in the middle of it due to being extended, understandably WiFi is non existent on the other side of that, another family property is quite large/old and every single wall is twin course brickwork, and not your modern aerated stuff, this is solid. The general rule is, if you have to go through more than one wall, you probably need another AP to extend coverage and if that wall is a solid brick wall, you may need another AP anyway for decent speeds.
As to mesh, it’s a nice idea, but unless you have a wired backhaul or live in a bed sit, it’s a compromised technology, it’s worse still if it shares the backhaul radio’s with clients as the cheap offerings often do. If you want decent mesh with a wired backhaul, AP’s probably make more sense anyway. As to why reviews vary, you have to remember that people expect mesh is some sort of magic that defies the physics of an environment where they already had issues, they usually don’t understand how it works or really want to, they just know if it’s faster or not according to the sync speed and perhaps the Speedtest app.
I've recently moved in with my in-laws and needed a solution to provide reliable network access upstairs as signal was very poor with unstable connectivity (dropouts on zoom, teams call, online gaming and would get a max of 20mbps on speedtest).
Running cable wasn't an option giving we're not here long term (fingers crossed).
I first used my old draytek vigor 2862 setup as an access point upstairs (configuring wan option to use the existing wireless network) but was still limited by the very poor signal upstairs so wasn't really a workable solution.
I tried some old power line adapters I had available but they were even worse performance.
I read up on mesh WiFi systems and opted for a set of tp-link deco M5 based on good reviews and that it was generally regarded as one of the better entry level options.
Got a 3 pack, plugged one into router in living room, the next into hallway downstairs to act as a relay and improve the coverage downstairs, final on top floor to improve coverage upstairs.
Setup was very simple, just a case of plugging them into mains and doing some very easy setup via tp-link app installed on phone. You also have the option to run ethernet and plug into one of the 2 rj45 ports on them to improve performance as they'll otherwise share available wireless bandwidth.
Its worked a treat, I now have very good signal and a stable 150mbps in the bedroom upstairs. I'm no longer experiencing any dropouts if I'm indulging in some online gaming.
In-laws who are also both working from home are also very happy as it's noticeably improved things for them as well.
Downstairs will get approx 400mbps (of 500) when close to the unit, dropping off as distance increases and obstructions get in the way of the signal.
Only other option I was considering was the Netgear Orbi rbk5x - very well reviewed but more expensive - it does have a dedicated backhaul channel though.
