I'm looking for a 3d monitor to be used with my xbox 360 and the odd movie in 3d. I want to test out 3d without shelling out too much. Here are the ones I have found so far.
Samsung S23A700D
LG D2342P
LG DM2780
BenQ XL2420T
I am unsure whether to go for passive or active 3d, as xbox may look better in passive despite the cut resolution. Apparently the LG monitors above come with the wrong glasses quite often, but can you buy these seperately or do you need to contact LG directly?
The BenQ looks to have the best picture quality from what I have seen, but does it come with glasses, and if not where do I buy these? The samsung is tempting but the BenQ might be better?
The DM2780 may be quite a bit more expensive than the D2342P, so is the extra 4" worth it?
Are there other monitors I have missed which are better or better value?
Sorry to ask so many questions, but I like knowing I have bought the right product.
Samsung S23A700D
LG D2342P
LG DM2780
BenQ XL2420T
