as igor has said, movie noise is an issue experienced on a lot of TFT's and none are really perfect. However, from a metre or two away, you wouldn't have any issues. Having said that, some screens show much more pronounced movie noise than others, and often on modern screens this is down to poor control of the overdrive technology. Samsung for instance have had a tough time with their MagicSpeed overdrive and the Samsung 970P and 930BF, while being fast, have unfortunately got some issues with excessive, or at least accentuated, noise in movie playback.
Viewing angles come into play as well, but there is no issue with viewing angles on an MVA or PVA screen really, especially if you compare them with a TN Film panel
The IPS technolgy can offer a slighter wider field of view, but there's nothing wrong with the VA varients in this regard really.
All i was saying in my post above is that the NEC isn't the most suited to movie watching. True, it i fast, and afterglow is certainly going to be at an absolute minimum. However, it's glossy screen is reflective and some people can find this off putting, not only in normal use, but in movie playback. If you're in the right lighting conditions, then you may well be fine, and as igors has said, he has seen no real issues with it. However, ignoring the panel technology for a second, the NEC's OptiClear filter is not really ideal for movie playback, and a traditional AR coating may well be preferable. Add to this the reports that the AS-IPS panel shows some excessive noise and it isn't really the screens strong area. As has been said, this noise isn't really a major issue in the right circumstances, and most screens show some anyway, but it is more pronounced than some other models for instance. That was all i was trying to get at really. Great screen, don't get me wrong, but personally i wouldn't choose it as a movie watching screen.
if it were my choice of the <£450 screens on OcUK at the moment for movie watching i think i would really consider these:
- Belinea 102035W - good panel all round, excellent price. only thing that would definitely make me wary of this would be the questionable and variable build quality. Possible back light issues might put me off
- Philiips 200W6CS - user reports are excellent, but there isn;t much info around at review sites. I'd probably wait a little to see more pro reviews but seems a good screen
- Viewsonic VX2025WM - same P-MVA panel as the Belinea, good all round performance. Not released yet so we don';t know about the build quality, but VS generally make excellent screens. Might be one to wait for i think
once again, i'm not saying that NEC is a bad choice, you may very well like it. but for me, the glossy screen is probably the main deterant if i was looking for a movie watching monitor.
