I've currently got one of these 2TB Seagate BarraCuda ST2000DM008, 3.5" HDD, SATA III - 6Gb/s, 7200rpm, would a ssd make much difference
Yep even a Sata SSD would make a huge difference
That's difficult to say without any information. What kind of SSD did you get? Do you have a separate HDD or partition for Windows? Is it big enough to store all of your data?well guys i took on what you all said. caved and got an SSD for windows. now my only question is: is it possible to transfer windows to it without having to do a clean installation? because i really cant be assed to reconfigure all the settings and everything again.
thanks.
Thanks bois - what do people recommend as the best solution if replacing a main hdd?
its a partitioned HDD at the moment. the SSD is a kingston A400 120GB intended to hold the OS and nothing else.That's difficult to say without any information. What kind of SSD did you get? Do you have a separate HDD or partition for Windows? Is it big enough to store all of your data?
Generally you can have some issues doing this without having the knowledge necessary, I would really advise to do the clean installation.
Then it shouldn't be a problem to just clone the partition, I can also recommend Macrium Reflect.its a partitioned HDD at the moment. the SSD is a kingston A400 120GB intended to hold the OS and nothing else.
Not only that, after nearly everybody suspecting corrupted Windows files or a very poor setup (even a 5.4k HDD should take 5 minutes after login to start Steam unless it's faulty), the OP ignores all that and wants to clone their Windows install. Despite never having doner so before and most likely they would have to shrink their boot partition too clone it over too.You ignored all recommendations and bought a tiny capacity, low end sata SSD?
