need help choosing memory
21 Aug 2010
Hey guys, never really been able to get my head around memory and im not the best when it comes to deciding what to choose. So i was wondering if you guys can help me chose between the following ? :
YOUR BASKET
1 x Kingston HyperX 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit - Black/Red (HX24C11BRK2/8-OC) £71.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £69.95
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) £65.99
Total : £217.52 (includes shipping : £8.00).
I understand the higher the mhz is better but i quite dont understand the timings which slightly confuses me.
I will be using it with an i7 4970k cpu and mostly for games like bf4 and wow.
I will appreciate if someone can chose the best one out of the 3 i have chosen or maybe recommend another memory? Thanks!
There will be minimal difference in performance as the higher frequency usually has higher timings.
If you have an aftermarket cooler i wouldnt get the lv ram as it may interfere with your cooler.
I would choose Kingston ram.
Thanks for all the advise guys!
Sorry i forgot to mention the cooler which i will be using will be a Corsair H105.
I kinda like the Teamgroup LV Xtreem and i think i remember reading somewhere that the new chips like higher frequencies on the memory? Forgive me if i am mistaken!
As for the g.skill that looks promising too and the timings look lower than the Kingston.
Weighing up the two: Teamgroup LV Xtreem LV has 2666 MHZ but has 11-13-13-31
The G.skill has 2400 MHZ but has 10-12-12-31.
The latency on the G skill is a lot better but the Teamgroup xtreem has 2666 MHZ. I am thinking anything over 2400 MHZ may not be a big difference? So i should stick with the G skill for the lower latency? If that makes sense :D
I think the Gskill may have a better chance of doing 2666MHzCAS10 than the Kingston does.
oops got them muddled up ! I meant 1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) £65.99
I've now edited it around.
Sorry :D
Stulid what would you choose out of the G.skill or the Team group LV Xtreme?
