Need Help Choosing Which Specs
19 Jan 2018
Need help choosing between these two specs for the HP Omen Gaming Laptop, not really sure which one is best, thank you.
HP Omen 15, version 1-
  • Windows 10 Home 64
  • Intel® Core™ i7-7700HQ (2.8 GHz base frequency, up to 3.8 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
  • 39.6 cm (15.6") diagonal Full-HD (1920 x 1080) display
  • 8 GB RAM with 128 GB PCIe SSD and 1 TB storage
  • NVIDIA® GeForce® GTX 1050 Ti (4 GB GDDR5 dedicated); Improved cooling; Upgrade access door; Anti-ghosting Backlit Keyboard; USB-C; Faster 2x2 Wi-Fi®
HP Omen 15, version 2-
  • Intel® Core™ i5-7300HQ (2.5 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
  • 120hz G-SYNC 39.6 cm (15.6") diagonal Full-HD (1920 x 1080) display for smoother gameplay
  • 8 GB RAM with 1 TB storage
  • NVIDIA® GeForce® GTX 1060 (6 GB GDDR5 dedicated); Improved cooling; Upgrade access door; Anti-ghosting Backlit Keyboard; Faster 2x2 Wi-Fi®;Thunderbolt port
Thanks, in advance
I'd pick the second with the 1060 and Gsync screen. The lack of a SSD is not ideal but the GPU and display should make up for it. You'll likely not notice much of a difference in CPU speed either.
