Hi
I was all set to order the remaining components needed to complete my build. I had my heart set on an asrock extreme 4, however they are OOS at every UK E-tailer
So now I need to choose another one, but have limited time for research (this bad bay needs to be ready to play D3 soon)
I want to spend around about £100. I can go a bit more if its worth it (absolute max ~£130ish)
I need it to:
OC my 3570k to 4.5GHz (maybe up to 4.7 if I get a golden chip)
OC my sammy green ram to a level that makes it worth me buying them in the first place (2000MHz+)
Must accept my Sapphire 7850, while also accepting my Xonor DX sound card in a pci-e 1x slot without effecting airflow to the GPU too much.
I would really like to be able to create custom fan curves for cpu cooler + case fans (not sure how realistic this demand is)
I would much prefer a full size ATX board (don't know why)
I don't care about:
Colour / Design
SLI / Xfire support
Any Ideas? I don't expect you to do all the research for me about all my demands lol, but if you think you might know the right board for me then I'll research it further.
Thanks
New Boy
I need it to:
I don't care about:
Colour / Design
SLI / Xfire support
Thanks
New Boy
